22' velocity prop help.
We just finished a 22' velocity project, it's an 89 model, 502 big block, hydraulic roller cam, roller rockers, 850 holley, aluminum heads and manifolds. Bravo drive with a bobs nose cone, and keikheifer trim tabs. We are running a 26 4 blade cleaver, not sure what kind, at about 5200-5300 rpm at around 80-82 mph. Trying to get the right prop for this, anybody out there with a similar setup, it seems there are alot of outboard velocity's! And not many inboards. Any info would be greatly appreciated!!
I'm not much help but your motor combo sounds similiar to the one I am putting in my 89 22' Velocity. My motor is a 454 instead of a 502 but it is built up with Dart heads, custom Bob Madera Cam and Stellings Headers making 500hp. I am going to run a 1.36 drive because I have it laying around with a 23 labbed Mirage plus. From what I have read the 22 likes the Mirage plus. I haven't finished putting mine altogether but I think if I have any issues or questions on it I will call the Velocity Factory and see what they recommend. I was hoping for low 80's and it seems that will be possible.
Just sold an '87 22 with a 735hp blower motor spinning a 30" Spinelli prop on a 1.5 Bravo with nose cone. Previous owner had it to 103 MPH at 5600 with throttle still left. I only had stones to get it in the high 80's, but I think boat could have used more prop if you had the guts or glory to go for it. Kenny at Velocity in Sanford, FL can tell you what to do to get boat to run fast safely. Good luck with both your projects! The 22 is a neat boat.
John
