Sea Pump Belt Sqeals >
Old 07-12-2012 | 09:09 AM
Default Sea Pump Belt Sqeals
My sea pump squeals when I fire the boat up for a few seconds then stops. It actually only does it when its cold and I give it some gas to help it stay running when I launch it. After it warms up its good, but then I notice it sqealing again around 3k rpms. Its been doing this for a while but just notice that my temp is going from 160 to 180 when it squeals. The belt is snug and last night I tried to snug it some more but its already tight.
Shoul my next step be replacing it?
s022mag is offline
Old 07-12-2012 | 10:37 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I would take the belt off and spin the idler and pump pulley's by hand to make sure the bearing's are not trying to seize . If the belt is tight it should NOT be sqealing under normal circumstances , tells me something is amiss !!
the deep is offline
Old 07-12-2012 | 11:22 AM
Like said above, might be the sea pump bearing. The parts to rebuild them are cheap compared to the pump itself, all you need is a press and some time, cost me about 100$ to rebuild mine, that price did not include a new shaft.
stopdropanroll is offline
Old 07-12-2012 | 11:44 AM
There isn't a idler pulley, the belt goes from the pump to the crank. Both sea pump and circulating pump was rebuilt last year. I'll try spinning it by hand.
s022mag is offline
Old 07-12-2012 | 12:04 PM
Come to think of it, it squealed last year after having the work done. I just assumed it was because the belt was cold and needed to warm up. It was only when the temp jumped up that I put 2 and 2 together. I guess I can call the dude back that rebuilt them.
Funny thing is it was done about the same time last year.
s022mag is offline
Old 07-12-2012 | 12:28 PM
Its a Mark IV engine with Vbelt. The pump will not spin by hand unless you remove the impeller. If was rebuilt last year, I would try the simple remedy first. Change the belt and make sure it’s TIGHT.
1BIGJIM is offline
Old 07-12-2012 | 01:21 PM
therer are only 2 places it can be tightened, right?
s022mag is offline
Old 07-12-2012 | 02:44 PM
I always tighten mine with a pry bar and some common sense to not make it so tight that it destroys the pump or belt. There is a decent amount of load on it when its pumping water.
Old 07-12-2012 | 03:49 PM
I see a bolt right above the pulley and 1 just to the right of the crank which i believe is where it can be tightened. I'm hoping for a bad belt, the pumps dont look fun replacing.
s022mag is offline
