525 EFI Injector Removal Tips??
Hi guys,
I want to pull the injectors out of my 525EFI and send them out for cleaning/ servicing.
Since this will be the first time I do this type of work is there any tips or precautions I should be aware of?
If anyone can offer up a step by step this would be great!
Thanks in advance,
Mike
Thanks in advance,
Mike
I thought about that approach and added a couple of cans of sea foam to my last tank of fuel, but wasn't sure if that would do the trick.
I could keep adding the injector cleaner and see what comes of it..
While it might seem extreme to pull the injectors, if you have a lot of hours on the motor it might be worth it. There's nothing better than seeing the before and after cleaning flow results along with injector spray pattern characteristics. Most injector cleaning services provide this. Running Techron, Sea Foam, BG44 etc. are all great, but they don't provide the hard baseline data.
Having an injector go bad, lean out or develop a poor spray pattern can wreak havoc in relatively short order. Mine dropped a valve seat as a result and did all sorts of damage due to a poorly performing injector.
i have an o.t.c. fuel injector cleaning kit,,,,it is used by pro,s to clean injectors on cars,,,,why woundnt something like this work,,,its uses the schrader valve on the fuel rail,,,and you use an air hose to pressurize it to 40 psi,,, basically its a mini fuel tank,,,with the cleaner as fuel,,and air hose as fuel pump to get it to 40 psi,,,only other thing is you have to plug or pinch off the fuel return line,,you buy the cleaner in cans as needed,,
I did do the high pressure filters (inline) last year. They have only 30 hours on them.
The issue started at the very beginning of the season, both engines down on rpm.
Did a scan, cleared all codes, and had 100% available power.
As soon as I changed the water/ fuel seperator filter one engine is running perfect at wot at 5200+ rpm, the other is still down.
Perhaps as suggested it would be wise to change out the inline filters first.
If I get them cleaned, then I know there cleaned.
Just need the brains to use it..lol.
