adding passenger gauges
Old 07-12-2012 | 01:28 PM
onesickpantera's Avatar
Default adding passenger gauges
I want to add an oil pressure and water temp gauge on the passenger side. Does anyone know if they need their own sender or if I can piggyback off the existing sender? My gut is telling me I can't piggyback because having two gauges hooked to one sender will screw up the ohms from the sender and cause the gauges to read low.
If I can't piggyback I will probably go mechanical.
onesickpantera is offline
Old 07-12-2012 | 02:00 PM
Depends on the sender you have now, if not all you need is a dual sender. (like you would have on a fly-bridge boat with two helm stations.)
senzaspectre is offline
