496 HO Sea Water Temp sensor location
I am trying to help out a buddy that has a 2001 496HO. He has been having some issues , as it seems to be going in to gaurdian mode at times. I connected the scan tool and the only thing I could find is that it says the lake/sea water temp is 431 degrees. I found the water pressure on the sea pump, coolant temp sensor under the heat exchanger, but where the heck is the sea water temp sensor?
You are correct, there are the ones on the manifolds, but they show up under a different sensor in the scan tool, port & starboard sides, but the ECU is still showing 431 degrees. I read some thread that said the early models had a sensor on the PS cooler. I looked and didn't see any on there, but there is a lot of parts, hoses and wires back there, so if it's there I might have missed it. Hopefully someone on here knows the exact location so I'm not spending wasted time locating it.
I was told that that was the default setting when it's not used
your best bet would be to call ray from raylar
All 496's have one sensor on each manifold. It's threaded into the surface just around the area where the riser mounts. The early ones were plastic and blend in with the manifold.. It has a 9/16 hex head.
The best replacements for them is the newer brass style because the old ones would break or fracture and sometimes you can't see that it is broken unless you remove it.
New part number is: 885342002 and they retail for around $26 each. Don't use the plastic ones even if they are available. It's a critical part to be made of plastic because it can put you in guardian sometimes when it's actually not hot..
They're mounted in the exhaust to help prevent operators from burning and melting the rubber exhaust hoses etc. Once it gets too hot it will sound alarm.
Also, on closed cooled engine, if there is a water flow restriction the exhaust will almost always get hotter and quicker than everywhere else so the idea was to put the sensor where it could catch rising temps asap..
When I think of seawater temp I think of raw water cooling. There is a separate transducer for that data link.
Kick me
