Major RPM Problems??
1990 502 mostly stock,usually 5200 rpm's max. I was out on the 4th ,and as I started to accelerate ,I was able to acheive 6000 rpm's and still had 1/2 throttle left. Right before this happened,I did hear a noise like I hit something. I drove back to the launch at idle speed. I pulled the prop off,and found a piece of plastic behind the prop. Something from the river not the boat. I take the boat for another blast,and now it seemed normal,but I lost about 5mph on the gps.Now the rpm's seemed back in the range. WTF......any ideas??
What are you runing for a prop?? If you are running a Merc Mirage plus or bravo, sounds like you spun out the plastic hub.
The good news is it is replacable, probably not a bad idea to go to a solid hub with the 502.
b t...the props fine. No vibration. I am starting to suspect either the coupler,or the clutch cones. Any thought's anyone. And ,how do I diagnoisis??I did talk to a friend who owns a Marina (shop),and his thoughts were the same as mine
How many hours are on the motor and the drive ? Sounds like a coupler to me, though it could be the clutch in the drive. Did you smell something burning when it happened?? The smell of burning rubber is a sign of a bad coupler.
