what should i offer for this?
Registered User
i am trying to work a deal on a 96 27 fever with trailer always in freshn water.here are the details.
1996 27 foot Fountain Fever
1995 Trailmaster dual axle trailer, with diamond plate side steps and aluminum wheels
454 mag EFI motor, recently professionally rebuilt by known engine builder in Rochester NY. .030 over will all new internals, block and heads were magnafluxed, block was line bored. Engine runs very strong and makes very good oil pressure, approx 30 to 35 hours since rebuild.
2004 Merc Bravo outdrive, unit was replaced in 04’ by previous owner, unit was brand new in 04’, when motor work was done I had the marina work done at a fountain dealer in Canandaigua NY, they went through the outdrive as well and everything was in great shape.
Merc Bravo 24 pitch 4 blade prop which was recently refinished and polished.
Gaffrig gauges and controls
Gaffrig GPS speedometer with memory
CD player with XM radio and 6 speakers
Porta potti
Upgraded to two group 24 battery system with remote battery switch
Silent Choice exhaust
Hyd trim tabs with indicators
Steering wheel drive trim controls
Engine fire extinguishing system
Drop down Bolster seats
Indy Graphics
Full boat cover
New cockpit cover (2011)
Embroidered cockpit carpet
Re-upholstered engine hatch(sun deck) spring of 2010.
Re-upholstered back seat bottom spring of 2012.
Porta potti
Indy Graphics
Full boat cover
Registered User
true but even if you have to put a block in it its still worth way more than a 96. he doesnt know if the motor is bad or not he hasnt run it. its a gamble could be fine could need a block the freeze plugs might have done their job
