Subtle pop
Old 07-21-2012 | 07:29 AM
Default Subtle pop
Hi all, so finally have my milky oil thang fixed and was out running at all rpms....other than at idle I would get a subtle pop or backfire
, couldn't tell if it was up thru carb or out exhaust. Temp is good at 175' oil is at 50 running hard...bad gas?...had about half tank from last yr and filled up with prem
But sound of pop was real subtle ?
Cheers pat
paintman is offline
Old 07-21-2012 | 08:07 AM
sounds like you might have a bad valve spring,what engine&what year.
mike tkach is offline
Old 07-22-2012 | 04:36 AM
Freshened up 522 with 5 hrs
paintman is offline
Old 07-22-2012 | 08:54 AM
Did you identify the source of the milkshake? maybe a valve either hanging up or not seating 100%?
Powerquest230 is offline
Old 07-23-2012 | 04:43 AM
Milkshake seems to have been solved with oil t-stat.........almost like someone hits a deep bass drumb, but hardly noticeable
paintman is offline
