Eliminate ignition keys in favor of push buttons >
Old 07-21-2012 | 04:00 PM
Default Eliminate ignition keys in favor of push buttons
I have replaced basically every part on my scarab except the stock ignition key switches and wouldn't you know I am having problems with one of them!
Thinking of eliminating the keys entirely and going with toggles for ignition and push button for starters. When I rewired the boat I changed around the way things were wired so I don't use the acc side of the key so not loosing anything there.
Anyone done this?
Pro's & Con's?
Jim
502ss is offline
Old 07-21-2012 | 04:11 PM
I left the keys and jist added starter buttons,,i like it because i crank the engines for about 10 seconds before turning the key so the engine has oil pressure..
FIXX is offline
Old 07-21-2012 | 06:55 PM
That's a good reason, like I said one of my keys is acting up so pretty sure the keys are going
502ss is offline
Old 07-21-2012 | 07:52 PM
32hustlin's Avatar
Registered User
I did it and it worked flawlessly i also added a plastic cover for the starter button in case I hit it with my knee I think I split two of the standard ignition switches before I got rid of em
32hustlin is offline
Old 07-22-2012 | 07:04 AM
not like the keys are a theft deterrent. boats are the easiest thing to hot-wire there is...except mayve riding mowers. OH RIGHT!!! SAME SWITCH!!!
dereknkathy is offline
Old 07-22-2012 | 11:32 AM
32hustlin's Avatar
Registered User
Lol so true I saw those push button starts with the keypad locks a while ago for "security" and had to laugh I could just imagine losing a motor trying to dock and frantically punching in combinations to get it restarted
Old 07-22-2012 | 12:09 PM
Was thinking similar....
Pwraddr is offline
Old 07-22-2012 | 12:24 PM
you think that's bad, try having one not restart on a twin shaft boat in a tiny little cove in front of somebody's fuel dock with 20 boats all around!! it only turns one way, and of course it is the wrong way...
Old 07-22-2012 | 01:22 PM
That's the situation I am in now. Got the boat in the water yesterday at the marina. Started port motor, fine. Shut off port motor started starboard motor ( I always do that so i can hear each run separately first) went back to start port motor, nothing!! Ended up having to jump the starter lead on the engine to get it to light!
502ss is offline
Old 07-23-2012 | 09:06 AM
I am going to wire my ignition with a toggle and push button this winter. I like the simplicity and the looks. I will hide a secondary switch behind the dash for security.......Chances are a crook won't be able to find that, and if they do, It is insured!
Gimme Fuel is offline
