5.7 liter efi (need help)
I have a 5.7l efi high performance engine and had fuel leak out of a pressure switch. On one side of the engine there is the fuel regulator at the fuel rail and on the other fuel rail there is a pressure switch. This is where I need some advice.
Merc part number 87-14355, this part is no longer avail.
Does anybody know who has one? Tried alot of places and no luck.
Has anybody found a part that will work for a substitute?
Thinking of removing and putting a plug in that spot, will this cause any issues?
I don't have a service manual in front of me but I think it is a 2 wire sensor where the normal running condition is an open circuit. Low pressure signals a ground resulting in an alarm and guardian mode.
To turn this monitoring capacity off you would reprogram the ECU to ignore. But in your case isn't really required
So In the KOEO,
1 - Leave the circuit open - test the result
2 - close the circuit - test the results
In one of those cases you should notice an alarm or definitive change in engine performance resulting in Guardian Mode.
So In the KOEO,
Yes you are right, the circuit is normally open. Sure seems like that part is nowhere in the nation,
I would like to have something in that spot instead of a plug, I have found some pressure switches
that are mostly used for nitros applications that seems like they would work.
Problem is the options are 15psi or 30psi and I believe the switch part number 87-14355 is 25psi.
Which one would you recommend? Higher or lower psi.
I hate gaurdian mode!
I have never had ecu go into gaurdian mode but sure don't like the sounds of it.
If I plug it (pressure switch) and keep circuit open and for some reason I lose fuel pressure will
this cause damage to engine or injectors? (thinking ecu wont adjust air/fuel mixture, don't know if this pressure switch would play any part of that or not?)
Also if ecu goes into gaurdian mode,
to get it back to normal, is it as easy as removing the terminals from the battery
or does it have to be re programmed?
