Access to step down pump? >
Old 07-24-2012 | 05:44 PM
Default Access to step down pump?
Does anyone know how to access the step down bilge pump for the Head/shower enclosure on a 37 Outerlimits?
JoeD is offline
Old 07-27-2012 | 09:34 AM
Not sure what you mean, you lift up the step on mine and the pump is right there.
richanton is offline
Old 07-27-2012 | 11:03 AM
tgersx's Avatar
Depends if your boat is side by side seating or not, if you cabin door is offset the way mine was with side by side seating. They had a pump under the sink in the bathroom and there was a hose that went to the floor and with a float to turn it on.
tgersx is offline
Old 07-27-2012 | 11:26 AM
sawzall lol
Pro1 is offline
Old 07-31-2012 | 05:03 PM
Yes mine is side by side with the cabin door off to the left,my pump is running but not pumping ---sounds like its mounted under the raised area the head is mounted to ----I might need to cut an inspection hole and put a hinged hatch.
JoeD is offline
