32-34 rough water handling >
Old 07-29-2012 | 07:05 PM
TEZ
Default 32-34 rough water handling
What brand handles the Lake Michigan 3-5 foot chop the best in the 32 to 34 foot range??? These are boats that can be purchased in the surrounding great lakes states. Thanks for any and all input.
Active Thunder
Hustler
Fountains
Powerquest
TEZ is offline
Old 07-29-2012 | 07:43 PM
Active Thunder
Hustler
Fountains
Powerquest
Both of these are forsale. The white yellow and purple 34' Phantom runs 104 mph (probably closer to 110 at end of summer with more prop testing and dialing-in), and the white and red runs 90-92 mph. Both boats have new (or almost new power), and new or almost new interiors. Both are located in New Jersey.
And run in rough water will run great. The 34' Phantom "Simmons Marine" is a great lakes boat , that has over 40 checkered flags (wins) in all kinds of water conditions, and I believe the 34' Phantom "Porter' Pipe Dream" is a great lakes boat (I do not know if Simmons or Pipe Dream are forsale). The 34' Phantom will be the fastest boat in the rough water with equal power to any of the brands you have listed above, and ride the best too.
Smarty is offline
Old 07-29-2012 | 08:09 PM
Full Force's Avatar
this is a good starting point.....
how much you looking to spend???
yeart ranges????
stepped or non???
Full Force is offline
Old 07-29-2012 | 08:14 PM
Nightlife1970's Avatar
Don't forget Powerplay and Baja's 33 Outlaw is regarded as the best hull they had.
Nightlife1970 is offline
Old 07-29-2012 | 09:14 PM
Formula seems to one i dont hear bad stuff about, the weight will handle the chop
pitmitch910 is offline
Old 07-29-2012 | 10:07 PM
Default fixx
bob porter has a 26 checkmate and i thoughta 29 or 30 phantom,,he just bought a new bigger building and even with that i dont think he will sell the phantom..
yes some of the formulas will slice through the waves,my 336 crush's them..
look into a cig cafe racer,,they 2 are wave crushers..
FIXX is offline
Old 07-30-2012 | 12:25 AM
This is the Pipedream 34' Phantom I mentioned earlier, as well as the Simmons Marine Phantom, and the 34' Phantom pleasure boat (with cabin) at WOT.
Attached Thumbnails 32-34 rough water handling-34%2520phantom.jpg   32-34 rough water handling-simmonsmarine.jpg   32-34 rough water handling-91mphocnj.jpg
Smarty is offline
Old 07-30-2012 | 05:04 AM
Full Force's Avatar
old school Cig and Apache will crush any other in "real" big water, straight hull and HEAVY will always be better, but you sacrafice speed, so again, I ask..... what years and price range we talking, I can sit here all day and say a 46 RR will be best but at 300,000 may be out of the price range....so this plays a huge role in the answer if you only wanna spend 30,000 or 400,000$$$$$????
Old 07-30-2012 | 05:51 AM
TEZ
Would be looking in the 85k and under price range, which can also to a certain degree dictate years right?? But probably in the 1995-2000 range, just depends on what guys are letting there boats go for. If non step is better in the chop I would probably go with that and also cheaper, don't need to go 95mph but would like to be able to run 75 -80mph.
TEZ is offline
Old 07-30-2012 | 06:40 AM
If you want a non-stepped boat in this size range the 33' Sutphen would be a great choice. Both the Phantoms I posted about for sale can be had for far less than $85K, and both are year 2000 boats.
Smarty is offline
