WANTED! Holman Moody water pump plate
I'm in desperate need of an old Holman-Moody, crank driven waterpump adapter for a buddy's old 351W Ford powered Donzi. The cast aluminum plate is all we really need as it seems the rest of the coupling is a Love Joy component. Anyone got one laying around???
Thanks,
Kurt 715-410-0735
Thanks,
Kurt 715-410-0735
I'm sure a machine shop could make one but was hoping someone had one laying around, just remove and replace. I'm told that the coupler is just a standard Lovejoy component. If someone had the plate it would be running for the weekend.
Any help would be appreciated!
Kurt
Kurt
switch your entire pump set up . . get rid of the totem pole bracket mounting plates and long bolts and switch to a crank hub mounted pump.
My Donzi Corsican had what you have, and when you break a belt in the middle of the pond, taking that apart to replace a belt sucks!
Mario L.
Mario L.
