38 cigarette vs 38 fastech vs 42 BT >
Old 07-31-2012 | 10:33 PM
Default 38 cigarette vs 38 fastech vs 42 BT
After the last poker run momma is ready to start looking at boats again. I am looking to be in the high 70's to mid 80's on speed would any of these setups see that?
96 cig 38ft with twin 502 MAG
98 fastech 38ft with twin 500's
43 ft BT with twin 500hps
What's motors does it take to get each of these boats to that number? I am looking for some reliable motors not some high HP that are rebuilt ever 150-200 hours.
FuelinAround is offline
Old 07-31-2012 | 10:44 PM
PhantomChaos's Avatar
Fastech with twin 500's (I don't think they had HP500EFI back then) will get you mid 70's. No idea about the others....probably slower. This is a stepped hull.....others are not (I don't think the BT is stepped).
PhantomChaos is offline
Old 07-31-2012 | 11:11 PM
thisistank's Avatar
Cig with 502's will run aroun 65. BT With 500's I assume would be the same (big boat!)
Really, those are very different boats.
thisistank is offline
Old 08-01-2012 | 02:06 AM
The 382 will run just over 70, maybe 72.
38 cig with 502 mags might hit 65
43 BT with 500's might just hit 70
Griff is offline
Old 08-01-2012 | 04:40 AM
boatme's Avatar
Cig (straight bottom) with 600's just under 80
BT with 500 HP's (this is a steped bottom boat) just over 70
Formula I am not sure
I owned both the cig and the BT mentioned above
boatme is offline
Old 08-01-2012 | 05:43 AM
Registered User
41 VELOCITY. big useable cabin. bathroom for momma, 500s 80- 84 mph. more power faster. Handles big water.
EXCESS ENERGY is offline
Old 08-01-2012 | 06:28 AM
BONDO10's Avatar
You can buy my 2004 382 Fastech with 525's and run 72-74 for less then $110k
BONDO10 is offline
Old 08-01-2012 | 06:37 AM
LapseofReason's Avatar
386 Sonic with 525's or 575's will run mid to upper 70's Active Thunder a little faster. Those will have the best cabin space. 382 fastec Formula is low 70's and there is no driver feedback, my buddy has one, nice boat but not a huge cabin, hard to work on the motors worse with a gen and you feel like your just steering it. Black Thunder, huge cabin I only like the GT the others look like a RV inside and no fun docking in wind. Cig is a great boat but slow with flat bottom and small power, most dont have the best setup or cabin for weekending. Need to nail down how much you wanna spend and what the cabin has to have, you have a Sonic now so unless you dont use the cabin or are both under 5 feet it will be hard to find alot of boats with the same head room.
LapseofReason is offline
Old 08-01-2012 | 06:42 AM
All the boats mentioned above were around 80k....I have pros and cons of all three. Boatme what was your feelings after owning hem, and I am guessing you mean 500s not 600's.
Old 08-01-2012 | 06:45 AM
purnell's Avatar
I have a nice kryptonite 39 w/500 efi's and xr drives for sale in the classifieds,runs 90 would go alittle faster with a little tweaking.
purnell is offline
