milky oil again !!
Old 08-02-2012 | 05:58 PM
Default milky oil again !!
Ok hers ther deal , last fall had some milky oil , made some too it was high on the stick like 2 quarts or so , found that the pcv tubes had come unhooked from breather , so I changed the oil twice and took it out ran a few times with the wife so not to fast ,35 or so no milky oil , well this weekend we took a guys trip down the mississippi and ran a good 300 miles got back and the oil is milky and has grown again by 2 quarts or so , Im thinkin oil cooler maybe ... higher water presure running faster and pushing in ... whats your thoughs???
speedfreek1 is offline
Old 08-02-2012 | 07:12 PM
bump..
Old 08-02-2012 | 07:19 PM
oil cooler sucking it in ...sounds good to me.
antisocial is offline
Old 08-02-2012 | 07:34 PM
You water pressure is maybe 15 psi max at WOT. Is your oil pressure lower than 15 psi? If so maybe that is the source of your water
Seriously, water can not over power oil pressure, you would simply lose oil out the exhaust, I would look elsewhere
4bus is offline
Old 08-02-2012 | 07:53 PM
Default fixx
likely not.....
bypass the cooler with a piece of 1'' pipe and go foe another cruise..you may have a bad intake gasket or head gasket or worsr a cracked block..
FIXX is offline
Old 08-02-2012 | 11:27 PM
I had water in the oil on a Carrera I had a few years ago. It was a bad intake manifold gasget.
Mach80 is offline
Old 08-03-2012 | 05:15 AM
300 miles with a water-oil mix for lubricant? i hope bottom end is ok.
dereknkathy is offline
Old 08-03-2012 | 06:38 AM
Yeah me too , never lost any oil presure though and oil is still mainly oil so , ive got my fingers crossed , will be doing some work tonight on it ...
Old 08-03-2012 | 07:55 AM
My guess would be head gasket. Hopefully not tho
JETDOC is offline
Old 08-03-2012 | 08:44 AM
TomFTM's Avatar
head gasket or most likely a cracked cyl head , under cylinder temp and cyl pressure the crack will open up.
TomFTM is offline
