vyper fresh water tank and pump location
Our fresh water pump stopped working and need to know where to access the pump. Does anyone know where it is located or has anyone done this themselves and can give any advise?
Hello, you have the same year as me. The pump is located in the bilge on the port side between the battery and the bulkhead. The freshwater tank is on the port side under the floor of the cockpit.
I try to post a pic of each.
I just looked closer at the pic it is missing in this picture. But you can see where it goes.
oh I think it's 6 gallon if it's even that, I wanted to see if a larger tank could be installed... going in with a mirror and camera this weekend after I look into my door issue first, I've heard these doors had problems I guess it may be my turn
