How to free up drive indicator? >
Old 08-05-2012 | 06:08 PM
Default How to free up drive indicator?
I can move the plastic ram by hand but it is very stiff. Wondering if it is the cable or the ram. When i am trimmed all the way down the indicator works, however when i trim up it only comes out an inch or 2 and stops there, so i am not getting a true reading on my drive indicator at the helm. Is there a way to help free up the cable or if it is in the ram should i take it apart and lube it with something? Thanks for any info.
RiReuter is offline
Old 08-05-2012 | 10:23 PM
Tinkerer's Avatar
It is probably the cable. I have had the same trouble - havn't found a good way to lube the cables.
Tinkerer is offline
Old 08-05-2012 | 10:40 PM
Ted G's Avatar
+1 on the cable, you will likely find it all rusted about 6 inches in from water intrusion.
www.cbpba.com
Ted G is offline
Old 08-06-2012 | 08:48 PM
Found this guy http://www.cpperformance.com/p-13610...eme-cable.aspx 20' for 50 bucks works for me, might need slightly more though, gonna pull the old one out this fall and measure it.
RiReuter is offline
Old 08-06-2012 | 09:54 PM
Ted G's Avatar
Look on the ends of the cable, there should be a number like 240 which is the length in inches.
www.cbpba.com
Ted G is offline
Old 08-07-2012 | 06:42 PM
RiReuter is offline
Old 08-10-2012 | 10:02 AM
My port side was doing the same thing. No amount of spraying took care of the problem. Had to replace the cable. There were two qualities of available cables. Only about $5 extra to get the better cable.
Wes Burmark is offline
Old 08-11-2012 | 06:42 PM
where did you purchase the cable from?
RiReuter is offline
Old 08-11-2012 | 07:05 PM
97FASTech's Avatar
Veteran: Army
Default Same Problem
Purchased a teleflex extreme cable from Wholesale Marine. 20ft for 53.00 shipped.
97FASTech is offline
