bravo 1 reservior hose connection? >
Old 08-06-2012 | 12:10 PM
Default bravo 1 reservior hose connection?
Where does the gear reservior hose connect to on the inside of the transum for a bravo 1? I have a barb hose fitting to the left of the cooling water intake hose ,, which looks to be the place. Just wanting to make sure.
crf311 is offline
Old 08-06-2012 | 01:12 PM
MnFastBoat's Avatar
Charter Member#157
Small barb 'could' be the speedo tube?
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 08-06-2012 | 05:41 PM
it's just above the shift cable, and has a e-clip that holds
it in
JaayTeee is offline
Old 08-09-2012 | 10:12 PM
it in
can you point it out in the picture?
[IMG][/IMG]
crf311 is offline
Old 08-10-2012 | 06:33 AM
bowtie's Avatar
The bronze barb is it. Thats the old style, not the plastic one with the e cllip.
bowtie is offline
Old 08-10-2012 | 08:46 AM
You should consider sealing the wood at the drive cutouts. Gelcoat is easy...
BenPerfected is offline
Old 08-10-2012 | 08:49 AM
Thanks, That's what I thought. Just wanted to make sure.
crf311 is offline
Old 08-10-2012 | 08:54 AM
I did seal the wood. I had to remove the inside flange to get all the wood covered. I just mixed up some fiberglass resin and coated it.It's just not painted. I found the cut hose after removing the flange and didn't know if it was for the speedo, or the oil reserve. Thanks
crf311 is offline
Old 08-10-2012 | 10:45 AM
Just an fyi, your speedo is the hex connector top right under the yoke
mr3dman is offline
Old 08-12-2012 | 09:37 PM
Thanks, That was my next question. Have a great day.
crf311 is offline
