502 GM Crate Engine? >
Old 07-08-2002 | 03:16 PM
Aces & Eights
Default 502 GM Crate Engine?
Is anyone running the 502 502 HP engines in there boat?
How is the idle with the factory roller? Does the engine make good power?
Old 07-08-2002 | 03:40 PM
I got two from www.1800runsnew.com 502, 435 hp service base motors. I have prochargers on them and they are strong and run great. No idleing problems etc.
Pure Energy is offline
Old 07-08-2002 | 04:53 PM
rjcardinal's Avatar
I put a 502/502 in a 22 Scarab last year. The engine ran great. Pulled a 27" Mirage about 5100 rpm. The cam is fine and the idle sounds great. Everybody asked me what was in it when they heard it idle. Never once stalled at idle. I bought the 502/502 short block and put some new rectangular port heads on it because I run in the salt sometimes. I milled the heads to achieve the same compression ratio as with the aluminum heads. 9.4 I think. I did change the valve springs because the stock double spring that came on the iron heads was not up to the lift of the 502/502 cam. I used a Comp Cams spring I dont remember the number but Jim Valeko from this site recommended them and they worked fine. I think I paid $3700.00 for the shortblock delivered to my shop. I bought from paceparts.com.
Ron
rjcardinal is offline
jeff32
30
11-16-2016 12:26 AM
gene
16
09-14-2009 11:02 AM
vandeano
3
06-04-2006 09:56 AM
Monty
4
08-20-2003 06:55 PM
Johno
2
01-10-2003 06:19 PM
