Mercruiser power steering
My low pressure hose has sprung a leak and unfortunately the metal tube that goes into the threaded fitting by the ram was rusted and bent while i was removing it. Otherwise I was just planing on getting a new hose and using hose clamps to the metal fitting. Is there an automotive power steering hose that I can use as a replacement? The mercruiser hose is insanely pricey like over $100 which I need to put towards other things. Thanks
I was able to get the low side fixed, my local auto parts store had a universal fitting kit that actually fit perfectly(I highly doubted it but figured I would buy it and try it and to my surprise it fit like oem). Now my problem is the dam high pressure hose has a crack in in the metal tubing near the fitting. Is there an automotive hose that I can use that any of you know of? Like from a certain car/truck model that would fit? Thanks!
Thanks for the help!
