Kill switch/lynard for a 88 baja..
I put mine in the ignition wire path after the key. In theory, you should be able to remove your ignition wire from the key, put it on one side of the kill switch, then run a jumper from the other side of the kill switch to they key where the ignition wire used to go.
Keyswitch > kill switch > ignition
