Equalizer bars w/electric over hydraulic brakes >
Old 08-13-2012 | 11:15 PM
Default Equalizer bars w/electric over hydraulic brakes
Now that I'm towing with an Escalade 6.0 ESV I am considering the advantages of a weight distributing hitch. I know that this set up will not work with hydraulic brakes but why would it not work with electric over hydraulic?
Anyone seen this done?
sprink58 is offline
Old 08-13-2012 | 11:47 PM
i use them, it works great
fossil fuel is offline
Old 08-14-2012 | 01:26 AM
Default fixx
they will work for either or,,i use to use the spring bars on my old snoemobile trailer when i had my 1/2 ton suburban with surg brakes,,stoped fine with no issues..
FIXX is offline
Old 08-14-2012 | 08:58 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
EoH no problem at all
Surge, if not set up properly, the tension applied to lifting the tongue will restrict the actuator movement diminishing braking. Not good.
With your setup, I would certainly switch to EoH. You will be pissed you didn't do it years ago.
Sydwayz is offline
