My first alarm
Old 08-19-2012 | 05:17 PM
My first alarm
2006 5.0 MPI. Had just refilled. Alarm every minute or so
Neutral invoked immediate stall, no wind thankfully.
The only two guesses I have are sender unit or water.
Gauges all normal, water temp a little low at 160
VtSteve is offline
Old 08-19-2012 | 05:32 PM
Rwbrew3's Avatar
I believe when it is going off every minute it is in guardian mode!
Rwbrew3 is offline
Old 08-19-2012 | 05:37 PM
Rwbrew3's Avatar
If you have access to a scan tool that would help narrow it dwn prety quick! Doesn't sound like its a fluid alarm, but would check all anyway!
Rick
Rwbrew3 is offline
Old 08-19-2012 | 05:56 PM
Well I was going to pull it this week for cleaning. Someone must have told the boat it is for sale. Hopefully my marina guy has the scan tool, I hate guess and spend.
VtSteve is offline
Old 08-19-2012 | 06:12 PM
Rwbrew3's Avatar
I hear ya, nothing worse than throwing money at it and still having the same problem!
Good luck!
Rick
Rwbrew3 is offline
Old 08-19-2012 | 08:44 PM
Have to check this out soon. What kind of alarm do you get with gear lube level?
VtSteve is offline
Old 08-19-2012 | 08:46 PM
Rwbrew3's Avatar
Gear oil is a constant buz
Rwbrew3 is offline
Old 08-19-2012 | 08:48 PM
Most likely the IAC is bad.
Griff is offline
Old 08-19-2012 | 09:03 PM
It wasn't constant, about once every minute or so. I had always wondered how loud they are, THEY ARE LOUD! Thankfully, I made it to the dock, even if the bow was almost impaled on a windlass.
I've heard about bad idle control valves, is that what the IAC is?
VtSteve is offline
Old 08-19-2012 | 10:14 PM
Expensive Date's Avatar
+ 1 if it stalled its the IAC.
Expensive Date is offline
