sbc cams
Old 08-19-2012 | 05:33 PM
Question sbc cams
just wondering who makes the best sbc marine cam these days,howards,comp cams,lunati voodoo,if you had these 3 to choose from,in flat tappet, if it was a roller than Bob M at Marine Kinetics or does he make a hydralic flat tappet to.
innerrage is offline
Old 08-19-2012 | 06:48 PM
Default fixx
i run the comp cams extrteme marine xm270h with crower cam saver lifters.this is what is sounds like..and yes with the rite valve springs (320 psi @ .500 lift)it will rev to 5800+ rpms...[YOUTUBE]http://www.youtube.com/watch?v=dLdeNiyk0Ew[/YOUTUBE]
FIXX is offline
Old 08-19-2012 | 07:58 PM
GPM
Originally Posted by mrfixxall
i run the comp cams extrteme marine xm270h with crower cam saver lifters.this is what is sounds like..and yes with the rite valve springs (320 psi @ .500 lift)it will rev to 5800+ rpms...http://www.youtube.com/watch?v=dLdeNiyk0Ew
Are they the Crower lifters that have the flat spot ground in them to let oil pass by when the engine is running ?
GPM is offline
Old 08-20-2012 | 02:08 PM
sounds awesome,probaly go with it,what kind of volvo drive do you run,Mrfixalli got a 290aq 14x23 ss outdrive 21ft boat deep vee,
Old 08-20-2012 | 05:28 PM
yes them are the ones,,i got the race versions,,they have a snapring instead og the wire clip to hold the plunger in..
its a volvo 280 no trim,,can it and go...runs 72 mph and will rev up to 6200 at that speed...anyday of the week with 4 people 68 @5800 rpm's..
FIXX is offline
Old 08-20-2012 | 09:36 PM
GPM
[QUOTE=mrfixxall;3758170]yes them are the ones,,i got the race versions,,they have a snapring instead og the wire clip to hold the plunger in..
I was just curious, my brother had trouble with those lifters.
GPM is offline
Old 08-20-2012 | 10:38 PM
I ran the same comp cams in my old nova II and loved them. good sound and great performance. I ran standard comp lifters and the recomended comp springs with no issues. brad penn oil. flat tappets need lots of zinc in the oil to be happy.
1fastlx is offline
Old 08-21-2012 | 12:57 PM
sounds good,i have the 350h.o 330hp @5000rpmsthis winter im up gradeing to the xm270h flat tappet kit,might run crower lifters and heaver springs ,see what the builder thinks,looking to make 400 hp and 425 torgue it has a edlebrock performer rpm intake,holley 650 carb ,ngk plugs,full msd ignition,4inch revolution marine aluminum exchaust,64cc vortec heads,full ss roller rockers.
Old 08-21-2012 | 06:39 PM
Good news is you have a lot of choices. I'm currently running a full roller Crower EFI series cam set up (LM00483) and it works great. I have about 70 hours or more on the motor with no issues.
Trash is offline
