502 efi crankcase ventilation question
ok, 94 502 efi What is the proper way to have these vented. Mine has 2 open pcv's (no hose, leaks oil) and two cheap metal moroso vents. These are stock valve covers. How are these supposed to be run and to where? Thanks
on my efi's the stbd side valve cover hole is directly under the air cleaner. the fitting there is a "T". the top is open so it blows into the air cleaner. the port side hose runs under the plenum over to the stbd side "T" fitting.
Thanks. I can understand how that works, unfortunately I have no occ holes in the vicinity of the air cleaner. Any suggestions?
