Kill switch not working
Old 08-20-2012 | 08:02 PM
Default Kill switch not working
With all this lanyard talk. I decided to test mine today. I wear it but in 10 years never tested it. So when I pulled it only one engine died ! So what do I look for?? It's a bone stock 92 35 fountain carb 502
flat rate is offline
Old 08-20-2012 | 08:58 PM
mikes280's Avatar
this would be a good idea for all of us to check ours , some twins have 2 but it can be done with one .
mikes280 is offline
Old 08-20-2012 | 09:37 PM
glassdave's Avatar
Neno the mind boggler
not sure if it is this way with boats but dont some kill systems work by grounding out the ignition system or some part of it? If so i would guess theres a loose or broken connection in that circuit.
08 OPA High Points Champion
glassdave is offline
Old 08-20-2012 | 11:33 PM
I have never driven a twin with one switch. But thats Me. Artie
akaboatman is offline
Old 08-21-2012 | 01:25 AM
My boat has one kill switch for 2 engines. It works. I've tested it by accident a few times at idle.
Griff is offline
Old 08-21-2012 | 08:56 AM
I'm going to look into it today I'll post what I find
Old 08-21-2012 | 09:35 AM
C_Spray's Avatar
Diamond Member #001
Unless you have a two-pole switch, you will need one for each engine. They work by interrupting the power supply (purple wire) to the engine's ignition system.
C_Spray is offline
Old 08-21-2012 | 10:23 AM
rchevelle71's Avatar
Mine gets tested by accident often, I forget I am wearing it sometimes. I have 3 kill switches in my boat, and one engine, installed one for each front passenger when it was setup as a 3-man. I ALWAYS wear mine at speed, but leave it optional for the passengers.
rchevelle71 is offline
Old 08-21-2012 | 10:33 AM
I have one kill switch and twins. I also have one key and two push start buttons. i would geuss mine is hooked thru the single key
drpete3 is offline
Old 08-21-2012 | 10:45 AM
I'm curious to see what you come up with. I have a 1990 38 fountain with the factory mercury lanyard, and I accidentally walked away with the lanyard. Mine only killed one engine also.
On mine I had to bypass a neutral safety switch on one engine, and I'm wondering if maybe the factory merc lanyard works in relation to the nuetral switch. I just put the boat back in the water and have yet to test it, but when I do I'll share what I found.
halfgassed is offline
