Prop question baja h2x 7.4 mpi >
Old 08-22-2012 | 05:35 PM
Default Prop question baja h2x 7.4 mpi
I currently run a 23 mirage + and see about 62 mph at wot at 4300 rpm actually see 4300 at 3/4 throttle with no increase when I pin it. Seems to take a bit to get on plane when loaded up and feels like it carries the bow a little high. What king of change would I see with switching to a bravo 22 p? Was thinking of picking up a used one to try
Larry
Z06vette1 is offline
Old 08-22-2012 | 09:19 PM
Larry
First off I think the prop is too big!! I believe the WOT rpm is 4600 to 4800 so I would be looking for a 21p Mirage.. A 22 Bravo I don't think will spin the rpm's you need unless you had it labbed..
fleg1 is offline
Old 08-23-2012 | 07:18 AM
Yeah, What he said!!!
Definitely sounds overpitched to me.... slow holeshot & low rpm on top end.
I think the 21 Mirage is good advise.
Thanks,
Tim Bostic
Hoss Marine Props
Tim Bostic is offline
