Draining your oil >
Draining your oil
Draining your oil
Old 08-23-2012 | 11:47 AM
Default Draining your oil
So I've been sucking the oil out of my boats for years through the dipstick, and I've never liked it. I'd like to drain it out of the pan and run it out of the transom drain. Can anyone recommend a reliable valve that I can install on the pan with a "nipple" or similar fitting that I could reach down and attach a hose small enough to route out the transom???
BBCLiberator is offline
Old 08-23-2012 | 11:50 AM
This is what I plan on using:
http://www.cpperformance.com/p-13338...20-thread.aspx
http://www.cpperformance.com/p-13339...75-thread.aspx
ebendrey is offline
Old 08-23-2012 | 11:53 AM
Rwbrew3's Avatar
The 20baja outlaw has a sweat set up, when you pull the drain plug far enough, the hose from the pan is connected to it. Just remove the fitting and out comes the oil, ALL OF It!
Rwbrew3 is offline
Old 08-23-2012 | 11:54 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do a search. It's been discussed on here many, many times. Mercury makes a kit for it.
Sydwayz is offline
Old 08-23-2012 | 12:01 PM
seafordguy's Avatar
I just pulled the drain plugs, attached a 90* fitting put some hose on it, ran it up front witha small brass plug/cleanout on the end of the hose. When it's oil change time I just hook a drill pump up to it and it pumps it out in about 3 minutes.
The only thing that sucked was that it sucked shimmying under the engines to put the fitting in.
seafordguy is offline
Old 08-23-2012 | 12:15 PM
Perfect, exactly what I'm looking for.
Old 08-23-2012 | 12:17 PM
I have Fumoto drain valves in everything except the boat, haven't got that far yet. They work great as long as the oil is warm, otherwise it's a slow drain. Positive lock when closed too! They do have a model with a nipple on it. I put a vaccuum cap on it to keep it clean.
inthetundra is offline
Old 08-23-2012 | 12:58 PM
This is what I just put in my boat a little slow, but faster than siphon and a whole lot easier. Pull the drain plug. pull out the hose, let it drain in pan and walk away.
http://www.wholesalemarine.com/p/32-...865281A02.html
ThisIsLivin is offline
Old 08-23-2012 | 01:44 PM
t500hps's Avatar
21 and 42 footers
I put these kits in my 382. I'd get home from the ramp, park in the garage, pull those hoses and open them into a bucket. Monday evening after dinner I'd go change the filter and re-fill with oil (after closing those hoses)
t500hps is offline
Old 08-23-2012 | 04:21 PM
onesickpantera's Avatar
Fair warning, some of those are too big for the hull drain hole. I use a second piece of hose that has a fitting with a smaller OD and put it through the drain hole from the outside. Then screw the two together.
onesickpantera is offline
