Need cam help >
Need cam help
Need cam help
Old 08-25-2012 | 09:12 AM
johnnyboatman's Avatar
Default Need cam help
Ive got talldeck 540s, with big brodix heads, 10.2.1 comp, 1150 dominators, cam# not sure, but on the dyno they pulled 650tq, 620hp i think the cam is the problem the builder says the heads are the prob. The heads are 365 i think is the number. I think the builder used some 500efi cams, im just wondering why these didnt make 700hp as to thats what i wanted and stated to the builder. So if any of you guys have some 540s single carb no blower please give me your cam specs so i can compare to see where i went wrong.
johnnyboatman is offline
Old 08-25-2012 | 09:21 AM
I'm pretty sure the 500 EFI cams are very close to the hp 500 cams. If thats true then the cams are your problem as they would be fairly small for your build. The 525 cams are quite a bit more powerful and would get you better results. The best thing to do would be to call Madera and have him spec out two cams. If your going to replace the cams with new roller cams the price will be the same if not a tad less and your engine would be optimized for how its built.
endeavour32 is offline
Old 08-25-2012 | 09:34 AM
For off the shelf cams, the crane 651 or 741 cam would do well. Or contact rmbuilder on here.
kvogt is offline
Old 08-25-2012 | 10:08 AM
I have a 540 with 9.7 to 1 comp. 1050 domimator. I would contact Bob Madera (Rm Builder 585-654-8583). He made my cam and it works great.
fbc25el is offline
Old 08-25-2012 | 11:25 AM
yes i think my cams are to small, guess i will get the numbers and go from there, when we started this the builder said 700hp was not a problem, now there done and 620hp is not what i wanted, but he says my heads are old style. there big brodix alum bb2 have been ported and other stuff. im thinking the cams are to small
Old 08-25-2012 | 11:26 AM
fbc25el what hp did yours make.
Old 08-25-2012 | 11:56 AM
I did not dyno the motor. But I had a crane cam in it and it would only pull to about 5400 rpm. I put one of Bob's cams in it and it would pull strong to about 5900 rpm. That was the only change I made.
fbc25el is offline
Old 08-25-2012 | 10:36 PM
articfriends's Avatar
Them little baby cams are holding you back, I made 657 hp with my 8.4-1 540s (less than ideal compression) with blower belt off with a cam from Bob Madera, with 10-1 compression and a cam ground optimized for running N/A I would expect a easy 700 hp, Smitty
articfriends is offline
Old 08-27-2012 | 01:17 PM
the specs are int-dur- 303-612-lift exh dur-311-631lift 114 lobe sep is this a small cam or?
Old 08-27-2012 | 07:58 PM
ttt
