Water leak...exhaust boot ?
Have a water leak while sitting...can't see it...exhaust boot is completly torn apart, has lightning headers and silent choice...did not think would leak thru there but ?? shift boot looks good ?? thanks Rob
only way it could leak there is if you have a y pipe and a bad seal at the transom.
u joint bellows,,,,shift bellows,,,,,or steer pin seal.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
not good,,,,,steer shaft seal sucks,,,,,,look forbrown residue on the tiller arm,,,, that will tell you if itc coming from there
