Fuel Pump Kill >
Fuel Pump Kill
Fuel Pump Kill
Old 08-26-2012 | 05:00 PM
Default Fuel Pump Kill
What would be the best way to wire an electric fuel pump when the engine is shut down? Threw lanyards or relay?
smcser is offline
Old 08-26-2012 | 05:04 PM
Default fixx
oil pressure switch to a real heavy duty relay..like a western snowplow solenoid..
FIXX is offline
Old 08-26-2012 | 05:41 PM
articfriends's Avatar
"hobbs switch" (oil pressure switch) to a nice relay-bingo!
articfriends is offline
Old 08-26-2012 | 05:57 PM
Rookie's Avatar
Here is the best pricing I found.
http://www.amazon.com/Mr-Gasket-7872...+Safety+Switch
Rookie is offline
Old 08-26-2012 | 10:22 PM
hobbs switch is the best way to control fuel pump .also a fuel return from the regulator to the tank helps too.
protechcoat is offline
Old 08-27-2012 | 06:14 AM
need to run power thru a relay, but I like to use a push/pull switch mounted at dash as a emergency/security override in between ignition and pump...
ezstriper is offline
