Weird Brake Pad Problem...
Old 08-26-2012 | 05:09 PM
Default Weird Brake Pad Problem...
So I replaced the brake pads on my 03' myco about 6 weeks ago and have a 1200 miles on them. Yesterday I noticed a squeek coming from the left side. I take a peek and find the actual steel plate that the pad is molded to rubbing on the brake disc... never have I seen this before. All was done like I normally do... lube the pins, lube the slides, ect... what gives.. ideas?
Also, I can take the caliper when its tight and rock it to make the pad hit the rotor where you see the wear... that should not happen. Ugh!?!
Attached Thumbnails Weird Brake Pad Problem...-image.jpg   Weird Brake Pad Problem...-image-2-.jpg   Weird Brake Pad Problem...-image-1-.jpg
teamsynergy is offline
Old 08-26-2012 | 11:08 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I don't know about the rocking. That sounds like something is cracked on the mounting plate. All of them, or just one?
However, I HAVE seen this interference problem with Kodiak disc brakes before. On my last trailer upon doing a brake job, I had this same interference. I called Kodiak and they said to grind down the steel edge of the pad so it does not hit. It wasn't a big deal and worked fine ever since.
Sydwayz is offline
Old 08-27-2012 | 12:29 AM
Its grooving every rotor... I pulled each pad and ground them to the pad mat'l thinking the same thing but no go. Thats when I pulled the pins and sliders and greased all of them again... and still no go. I plan on calling myco and kodiak today...
