High Oil Pressure from Mercury 377 Scorpion Engines >
Old 09-02-2012 | 09:54 AM
Default High Oil Pressure from Mercury 377 Scorpion Engines
I recently purchased a used boat with twin Mercury 377 Scorpion Engines with approx 200 hours on them. I noticed the oil pressure on both engines run approx 75 to 80 psi at 3,000 RPM. Is this normal for these engines?
It seems a bit high as I'm used to the Mercury 454s. Also the boat has new Livorsi guages thru out.
Does anyone have any experience with these engines?
Chase is offline
Old 09-02-2012 | 11:58 AM
Are you sure you have the correct ohm senders for the new Livorsi guages????
Griff is offline
Old 09-04-2012 | 08:46 PM
How would I go about determining the correct ohm senders for my gauges? I have very little experience with installing gauges.
Fixed - wrong sender - thanks Griff.
Chase is offline
