WTB #5 gimbal bells and caps >
Old 09-04-2012 | 09:36 AM
RMPRam's Avatar
Default WTB #5 gimbal bells and caps
I'm looking for a pair of #5 gimbal bells and the caps for the 1" side pins. I have a pair of #5 gimbals and the bells are worn out but the gimbal rings and the transom housings are in great shape. Anyone know where there are some #5 gimbals that might have broken rings or transom housings, but the bells are still good? Finders fee if I can locate a good pair of bells and the 4 caps.
Gary
612-247-7081
RMPRam is offline
Old 09-04-2012 | 10:07 AM
CcanDo's Avatar
Gary, I have a set of gimbals.....However, the vertical pin is frozen on one of the two. (never tried to knock the pin out) The transom studs are good (they were on box's) They will refinish to look new.....They are gen 1, not gen 2.
CcanDo is offline
Old 09-04-2012 | 10:23 AM
RMPRam's Avatar
Thanks for checking. They have to be 2nd design with the 1" pins.
Attached Thumbnails WTB #5 gimbal bells and caps-57-const.-5-gimbles-gear-case-066.jpg   WTB #5 gimbal bells and caps-57-const.-5-gimbles-gear-case-063.jpg
RMPRam is offline
Old 09-04-2012 | 10:49 AM
CcanDo's Avatar
I know you know more about #4/5 gimbals than we do ! However, the pins are 1" and it is assumed the only difference between 1 and 2 is aesthetic ??? These gimbals are clean enough to go back in service after the usual rebuild kit and that pin.
CcanDo is offline
Old 09-04-2012 | 11:17 AM
CcanDo's Avatar
Gary, BTW, we still have that set of # 5 gears. Net forged, nitrited, splined, mounted bearings, shims, 1.50 ratio, never run, new....you need those !
CcanDo is offline
Old 09-04-2012 | 01:28 PM
RMPRam's Avatar
Straight cut gear or spiral cut?
RMPRam is offline
Old 09-04-2012 | 02:14 PM
CcanDo's Avatar
Straight
CcanDo is offline
Old 09-05-2012 | 11:44 AM
CcanDo's Avatar
Gary, Whereas, you are the # 5 King....The gimbals and gears would make a good package. Correct me if I'm wrong, all of those parts should fit #4, # 5 and 3's ???
CcanDo is offline
Old 09-05-2012 | 04:44 PM
RMPRam's Avatar
If the gears came out of a #5 drive, they are only used in that drive and a #3A. They will not work in a #3 or a #4 drive.
RMPRam is offline
Old 09-05-2012 | 05:13 PM
CcanDo's Avatar
Sorry, I meant to say 3A, for the 4's, Keith Holmes made an up date to 4's before we got that set drives. I don't remember the details.
CcanDo is offline
