I need Seal Kit for Marine Machine Steering Ram >
Old 09-04-2012 | 06:04 PM
Strip Poker 388's Avatar
Rob
Question I need Seal Kit for Marine Machine Steering Ram
I sent Bing a email to the smokeshop with no response,I tried finding a phone # ,old one disconnected.Anybody got any contact info or somewhere I can order seal/orings.I believe its just the outer seal/prob a double lip.
The ram is staring to drip a little fluid at the seal,very minute amount,Maybe one drop per 3 days,level has not even changed,its not worse when running either,weird, I did see a little something on the male shaft that I could hang my fingernail on,I took some 2000g and smoothed it out but it wasn't enough to nick the seal.
Thanks for any help
Rob
Attached Thumbnails I need Seal Kit for Marine Machine Steering Ram-img_0101-medium-.jpg   I need Seal Kit for Marine Machine Steering Ram-outdrive-1-14-2010-062-large-.jpg   I need Seal Kit for Marine Machine Steering Ram-img_0011-custom-.jpg
I need Seal Kit for Marine Machine Steering Ram-emerald%2520beach%2520poker%2520run%25208-2007%2520098%2520%2528large%2529.jpg   I need Seal Kit for Marine Machine Steering Ram-sterring-damaged-drive-004-large-.jpg   I need Seal Kit for Marine Machine Steering Ram-outdrive-1-14-2010-128-medium-.jpg
I need Seal Kit for Marine Machine Steering Ram-outdrive-1-14-2010-154-medium-.jpg
Strip Poker 388 is offline
Old 09-04-2012 | 07:38 PM
you can still get them from bing. you will have to find someone else to install. I had a local hydraulics company do some, and they said they could get seals.
PPlay33 is offline
Old 09-04-2012 | 10:03 PM
Rob
I tried to get them from him
Old 09-04-2012 | 10:13 PM
Rookie's Avatar
I need to rebuild mine also. I plan on taking them to my local hydraulic shop when I get them apart. They are just a standard cylinder that are very pretty. They say they have done a dozen over the years and are off the shelf seals.
Rookie is offline
