Go Back  Offshoreonly.com > General Discussion > Boating Safety
Kill switch/tether recommendations >
Old 09-06-2012 | 05:09 PM
Default Kill switch/tether recommendations
I'm assuming my boat was not built with them and would like to add them before the next run. Is it better to have 2 separate switches or do they make one for twins with a single tether? Any recommendations, advice? Thanks
prostock85 is offline
Old 09-06-2012 | 05:19 PM
$10-$100, lots of them out there. Get one for each engine
inthetundra is offline
Old 09-07-2012 | 03:02 AM
Depends how you want to do it. You can wire one switch to kill both if pulled. Can be purchased about anywhere just depends on your appearance preference. I actually was gonna wear mine last saturday on our run and found out I'm missing a clip on one of mine. They are definitely there for a reason and should be worn. Especially if your out running hard. Ejection for one is a real situation and you wouldn't want an unmanned boat wot towards your family would ya....
Adamcoover is offline
Old 07-06-2013 | 12:28 PM
I just installed 2 on my boat. I got them off amazon. I started a thread under do it yourself and there is a link on there for a single tether dual engines.
s022mag is offline
Old 07-06-2013 | 12:43 PM
http://www.cpperformance.com/p-13200...op-switch.aspx
Crude Intentions is offline
Old 07-10-2013 | 12:18 PM
fireboatpilot's Avatar
RIPSTA Racing Team
They make one for twin engines which I recommend. I didn't want two more holes in my dash and then theres the issue of two teathers. I have mine down low on the dash and have a velcro band that I wear around my ankle.
fireboatpilot is offline
Old 08-01-2013 | 02:21 PM
I had one go bad on my last boat, so in the name of getting out on the water on a Saturday morning, I ran to Academy sports and bout one off the shelf. Just FYI to anyone in the same situation, they are wired backwards. Cl.osed with the tether attached, the motor wouldn't start. With it in the open engaged position, it would. Returned it, got another, same situation. I ended up taking it apart and rewiring it correctly. Not sure if it was jut a bad batch or not, just thought I'd pass that on.....
txtraveller2002 is offline
Old 08-05-2013 | 05:58 PM
i think mercury racing makes one
sparky24 is offline
Old 08-06-2013 | 11:23 AM
Velocity Vector's Avatar
Crazy Energy
[ATTACH=CONFIG]505652[/ATTACH]
http://www.ebay.com/itm/ECM-CLEAR-AN...687d88&vxp=mtr
I picked of a couple of these the other day.
Attached Thumbnails Kill switch/tether recommendations-%24t2ec16dhjgwffyr14jiebrzzmozcf-%7E%7E60_57.jpg
Velocity Vector is offline
Old 12-12-2013 | 01:06 PM
MnFastBoat's Avatar
Charter Member#157
This is what I put in mine 10+ years ago!
Best one, easy to install and works fantastic!
Originally Posted by I.C.U.Lookin
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
