CMI gaskets
Would like to have input on which header gaskets to use for CMI E-tops with (cool collar)? Heads are GM 088.
Also does the E-tops typically use rope seal or gasket?
(I'm currently away from the boat).
Thanks. The Fel pros I got from Summit last time had very little material covering the header flange can't remember the part# though.
Lil red, do you have a part # for the gaskets you have been using?
