Summit Twist-tite hoes failed >
Old 09-12-2012 | 09:24 AM
Default Summit Twist-tite hoes failed
we had talked about this a while back...tried the summit brand twist-tite #10 when I plumbed my boat, nice to work with, after about 1 year of use, but less than 20 hours, noticed oil pressure acting funny..check oil..was low...4.5 quarts !! started checking..saw oil in bilge, but so hard to see on my boat could not tell much..traced to main oil line coming off block adapter had pushed back about 1/4-3/8" and leaking badly. pushed back on and put a hose clamp on for a temp fix...talked to summit, shipping me some aeroquip hose to replace...just letting anybody out there running it to watch out...Rob
ezstriper is offline
Old 09-12-2012 | 03:00 PM
You are lucky that it did not blow off altogether. I considered these as well, but decided to go with a set of braided stainless and AR fittings.
Budman II is offline
Old 09-12-2012 | 03:04 PM
I know....last boat did S/S..coast guard does not like them because they can short..so was trying something else....was assured these would be fine...so far only one was a issue...
Old 09-12-2012 | 03:38 PM
I was reading that on the two barb fittings you need a clamp too... kinda takes the easy part out of the assembly though.
VetteLT193 is offline
Old 09-12-2012 | 03:45 PM
they say no clamps needed....not sure if that holds up now...
Old 09-13-2012 | 04:59 PM
summit sent me aeroquip hose, changed all of it out today, put clamps on just be sure all my fittings were 3 barb...hope these work better...hose was a lot different so we'll see...
Old 09-13-2012 | 08:34 PM
johnnyboatman's Avatar
i always clamped mine also,just peace of mind.
johnnyboatman is offline
