Mph ????
Old 09-16-2012 | 08:46 PM
Mph ????
I have a 25' sxt warlock cat that I'll be installing a blown 565 w/ about 800hp. will it handle a 32p bravo one 4 blade & what should approx. mph??? around 58- 6200 rpm.
dave269 is offline
Old 09-16-2012 | 08:52 PM
what gear ratio are you running
abones is offline
Old 09-16-2012 | 08:55 PM
assuming the drive is 1.5 ratio,800 hp should spin the 32p prop near 5500 in that lite cat,just my opinion.
mike tkach is offline
Old 09-16-2012 | 09:02 PM
agree +1
abones is offline
Old 09-16-2012 | 09:11 PM
Thumbs up
That 25 is a good looking boat!
Any Pics?..
PokerRun388 is offline
Old 09-17-2012 | 09:06 PM
1.5 gear ratio
dave269 is offline
Old 09-17-2012 | 09:49 PM
Turbojack's Avatar
http://www.go-fast.com/Prop_Slip_Calculator.htm
114mph if it can pull 6200
That is unless your X is too low
Turbojack is offline
Old 09-17-2012 | 10:20 PM
what slip % are you using? 10% is real good %
That would be sweet 114
abones is offline
Old 09-18-2012 | 06:18 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
I hope you have a drive that can handle the power. Your boat being a single engine cat can be very rough on drives (aka the guy pushing the throttles forward). Be EASY getting the boat onto plane, put a little trim in it and try to be smooth with the throttle and it should last for a while.
If the prop does not work, do not force it to work... you could very easily break the drive or possibly hurt the engine.
New Prop, $550..
New Drive, $5500++
-Eric
teaguecustommarine is offline
Old 09-18-2012 | 09:07 PM
Is 10% prop slip about average ? what other options besides the 32p bravo one 4 blade would be recc to lower the % ???
dave269 is offline
