epoxy for transducers? >
Old 09-20-2012 | 07:50 AM
Default epoxy for transducers?
Do I have to use the expoxy glue that came with my depth finder to install the puck transducer? Can I just use the polyester resin that I'm currently using to fix the boat? I would think the bond would be stronger if I glued it now before I painted the bilge. I think somewhere along the line I heard the polyester resin might heat up too much causing damage to the transducer?
FBRONCO is offline
Old 09-20-2012 | 08:27 PM
ttt
FBRONCO is offline
Old 09-20-2012 | 10:10 PM
rw40426's Avatar
I use Marine-Tex epoxy, you need something that is slow cure so you don't get any air pockets under the transducer otherwise it will not read properly.
rw40426 is offline
Old 09-20-2012 | 10:18 PM
c_deezy's Avatar
I used 4200 after I painted the bilge.
c_deezy is offline
Old 09-21-2012 | 06:26 AM
Too Stroked's Avatar
You can use virtually any adhesive - as long as you don't get any air bubbles trapped in it.
Too Stroked is online now
Old 09-21-2012 | 07:32 AM
I have had transducers that would not work after being installed with 3M 4200/5200.We removed them and used slow cure epoxy and worked fine.
brian41 is offline
