Replacing foam on engine hatch question >
Old 09-23-2012 | 10:42 AM
Default Replacing foam on engine hatch question
Anybody replace their foam on the engine hatch? Mine is settled and causing a low spot in the middle of the hatch. It looks like the large Philips head screws around the perimeter hold the cushion/plywood? Is there more screws under the mirror? Thanks
bonesmalon is offline
Old 09-23-2012 | 11:33 AM
camptappakeg69's Avatar
On my Tantrum there was a screw in the middle, maybe two, when I took it off. No mirror on the hatch though.
camptappakeg69 is offline
Old 09-23-2012 | 06:43 PM
ActiveThunder's Avatar
Correct. Just the screws you see. And what you are seeing is the foam on the top side of the "box" of the hatch. Once you pop it off you can replace the foam.
ActiveThunder is offline
Old 09-23-2012 | 06:56 PM
Thanks!
