Winterizing 7.4 efi on stand >
Old 09-23-2012 | 02:53 PM
Default Winterizing 7.4 efi on stand
I have a 7.4 efi merc. Engine out of boat/on a stand. It was test run down south but now is in n my garage w/winter on its way.
What are the steps to getting water out of block,fuel cooler,etc...
Any tips and advice?
JETTDOGG is offline
Old 09-23-2012 | 03:46 PM
obnoxus's Avatar
Charter Member #1171
Disconnect all water hoses and drain plugs in block....
reassemble and fill with RV antifreeze through the thermostat hole in the intake for added security
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 09-23-2012 | 09:50 PM
I would just drain it. Like said, pull hoses, block and manifold drains and you are done.
f_inscreenname is offline
Old 09-23-2012 | 11:19 PM
Pull all the hoses and drain plugs (on exhaust manifold and block drains) and blow compressed air through them. I drain my block and exhaust after each use.
Trash is offline
Old 09-24-2012 | 12:35 PM
Thanks to all
JETTDOGG is offline
Old 09-24-2012 | 07:47 PM
Expensive Date's Avatar
In Maine as stated I would drain and blow out, but then use car antifreeze or at least the -100 (purple) RV stuff. You guys get cold up there.
Expensive Date is offline
