difference between a hydro and a bravo 1 >
Old 09-26-2012 | 11:42 PM
berns29scarab's Avatar
Default difference between a hydro and a bravo 1
what are the differences between the hydromotive 4 blade say a 27 pitch and a 28 pitch bravo 1 4 blade. single engine vbottom
berns29scarab is offline
Old 09-27-2012 | 07:37 AM
I know they make a cleaver and a round ear..
excalibur82 is offline
Old 09-27-2012 | 09:15 AM
Was talking about how it affects boat. Stern lift or bow lift etc...stock bravo 1 4 blade to a hydro P seriers
Old 09-27-2012 | 09:27 AM
Bravo= bow lift
Hydro= stern lift
POWERPLAY J is offline
Old 09-27-2012 | 06:18 PM
bravo 1 vs hydro p4x? Very similar prop....hydro has more rake (blades have higher angle of entry). This is supposed to give more bow lift. There is also more surface area so may give a little lift to the transom. better cruise and MAYBE better top end...that depends on your boat. Try it out and report back.
vtown is offline
Old 09-28-2012 | 12:05 AM
thanks
Old 09-28-2012 | 04:26 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Hydro does not have more rake angle or blade area.
The Bravo 1 will react better to trim which can create less wetted surface area and decrease drag which can make you go faster.
The Hydromotive has more stern lift and on a set up that wants to run flat, it can be the better performer.
Brett
[email protected]
bbladesprops is offline
Old 09-28-2012 | 07:35 PM
Advantage 27's Avatar
Brett
Brett,
How about the Hydro Quad IV-X?
thanks
Advantage 27 is offline
Old 09-30-2012 | 08:12 PM
Smile
Reversed engineered B1 with diferent TE cups. (copy.....not as good)
Truely
B
[email protected]
