Gel or Paint
Old 09-28-2012 | 04:54 PM
Registered User
Default Gel or Paint
Hi..I have a hull 35' which has being painted over the gel..(by previous owner), the paints looks tired and starts pealing..here is the question...re-paint the hull or gel now?
What do you guys think? Looking for the best and most economic solution here...Thanks!
Marzug is offline
Old 09-28-2012 | 05:29 PM
I'm in the same boat! I have a 32ft hull and im in Columbus OH, I wondering the same thing, and if their is someone local, or in Ohio that is able to do asap, and at a reasonable price!
Dmann1 is offline
Old 09-28-2012 | 06:44 PM
if your boat is peeling the paint is going to have to come off either way..if you try and top coat it with gel it will blister and look like chit when the gel hits the paint..its going to be a hard call with out seeing it and experimenting with whats their now..
FIXX is offline
Old 09-28-2012 | 06:49 PM
vintage chromoly's Avatar
there is no "economical" solution. i'd strip it down and start from scratch with a gelcoated running surface and painted sides, transom and deck.
vintage chromoly is offline
Old 09-29-2012 | 01:40 AM
Registered User
Any idea what the best case scenario is here..ie cost wise getting the paint of and gel coating her? Average..??
Also I have being told that once it's painted it's better to leave it painted, and paint has a lot of advantages over gel?
True or not?
Thank's!!
Marzug is offline
Old 09-29-2012 | 01:48 PM
glassdave's Avatar
Neno the mind boggler
True or not?
Thank's!!
Gel would cost more, likely MUCH more. Gel is very arduous to apply. You are better off going with paint especially if it has been painted once already.
08 OPA High Points Champion
glassdave is offline
Old 10-02-2012 | 01:57 AM
and if you leave it in the water then your better off leaving it alone because it will look the same way it does now and will be a waste of money...
FIXX is offline
