Go Back  Offshoreonly.com > Owners Forum > Donzi
2009 35' 2x496/425 how fast? >
Old 09-28-2012 | 08:21 PM
Default 2009 35' 2x496/425 how fast?
Greatguy66 is offline
Old 09-29-2012 | 02:20 PM
Nice one for sale just curious!
Old 09-29-2012 | 03:05 PM
I'm trying to remember, I think like the 79-82mph range. somebody else can confirm, but that rings a bell.
tom
FISHIN SUCKS is offline
Old 10-12-2012 | 10:16 PM
If you cheat - low on fuel, no extra weight, ( I mean none), going with the wind, going with the current, and going with the tide - I got 83.3 GPS with tattle tale to prove it. Now, on a normal day, with all bets off, you'll be lucky to see 79. 4 Typically, you'll see 78.5 In bad conditions, you can sometimes only see 76.6. Some in this hobby think choppie water helps, but I have found that the smoother the water the better speeds. Hope that helps.
RumBlur is offline
Old 10-14-2012 | 01:42 PM
It does Thanks!
Old 11-20-2012 | 04:46 PM
I have a 33zx with 500 hp efi's and I could only get 80,82 out of her. So would think slower then that for a 35 with 496s.
1989mach1 is offline
Old 11-21-2012 | 08:25 AM
The 35 ZR is shorter in height which makes for a lighter boat. A longer, lighter boat will run faster than a shorter, heavier one.
I think the 35 is in the neighborhood of 1000+ pounds lighter.
I think the 009 edition is even lighter than that, they have a different cabin that is lighter... the 009's are supposed to run 83-ish with stock 425's
VetteLT193 is offline
Old 11-21-2012 | 07:16 PM
Will run 77-78 all day. Best I have ever seen is 79.5.
Donzi Andy is offline
