winterizing
Old 10-12-2012 | 10:14 PM
Default winterizing
Hey guys I was wonder if any body has any way to winterize a block with out starting it as I'm just starting to fix the port starter
HEDGEHOGER is offline
Old 10-12-2012 | 10:23 PM
I assume regular merc big blocks? Just pull all the hoses, drain the block, exhaust, and any coolers, then refill from the thermostat housing. Piece of cake! ....except getting to some of the clamps and drains.
RT930turbo is offline
Old 10-13-2012 | 06:25 AM
The block sometimes won't drain cuz hole has stuff plugging it. Take a poker of some sort and clear block drain holes out. One guy mentioned a shop vac on the hoses. Would also make sure any coolers are emptied.
dereknkathy is offline
Old 10-13-2012 | 08:56 AM
Coat hanger works well in block drains I have used a sump pump to push antifreeze also that's how I do a/c units
353Formula is offline
Old 10-14-2012 | 01:07 PM
went to winterize the boat this morning and couldnt find the holes in the bottom of the block so i just drained the hoses and refilled the block with antifreeze through the hoses now im just hopeing the blocks full guess we'll find out in the spring
Old 10-14-2012 | 01:30 PM
I took a 5 gal screwed a outdoor hose into the bottom- side attatched a legnth of garden hose to the spicket and my water ears on the drive.
Put a few gallons of anti-freeze in the bucket and set it higher than the drive.
Start engine open spicket and fast idle until i see only anti freeze coming out the exhaust.
Leaves pure a/f in engine.
Best part is no screwin w/hose clamps, etc. And you can use it year after year
JETTDOGG is offline
Old 10-14-2012 | 02:15 PM
Default Fixx
That is not the way to winterize them..you have to pull the plugs on the side of the block or they will freeze and crack the blocks..they are center of the block a little above where the oil pan bolts to the block..
FIXX is offline
Old 10-14-2012 | 02:55 PM
+1 you WILL have cracked blocks come spring. You need to find the drains and drain them, or use the bucket method mentioned above.
Old 10-14-2012 | 03:24 PM
Do you warm up first to get stats open? Ihave always ran motors up to temp first to ensure all cooling passages are full of a/f.
looseconnection is offline
Old 10-14-2012 | 03:27 PM
That is not the way to do it. You need to drain the blocks. If you can't even find the block drains, you should be having a professional winterize it. You're risking 20k worth of engines to save $200.
Griff is offline
