anyone put 1200hp to mmx billet drive >
Old 10-18-2012 | 01:42 AM
Default anyone put 1200hp to mmx billet drive
has anyone put 1200hp to a max machine works all billet drive? how is it holding up? i know the lower is fast and cant decide if i need the all billet mmx drive OR an imco scx upper with the mmx lower. im sure im going with the mmx lower just not sure about the upper. thoughts please! it will be on a 3800lbs htm ss24 cat with 1200 turbo hp. its about 2k more to go with the scx upper because of the new helment and resovior.
La/stryker is offline
Old 10-18-2012 | 06:06 AM
bor's Avatar
bor
There s à Guy Jeff who have the blue white rpm redline whit 1000+on several drives and ended up whit the scx -4 that hold up till now
I tought his screen name is 26 redline there s a thread on here about scx where hè chines in
bor is offline
Old 10-18-2012 | 06:31 AM
I ran the MMW full billet drive for 6 years. Motor made in the beginning 1100 & in the end 1250. The set up was in a Howard Bullet with not overly aggressive X-Dimension. I changed oil in the drive every trip out /checked my magnets. I used to change out the lower gears between 40-60 hours. Never changed an upper gear! Yes the lower is extremely fast!! I would call Aaron & Jason there great guys that have a awesome product. And you wont find any better customer service in the business.
NMBullet is offline
Old 10-18-2012 | 05:05 PM
how many hrs total do you think were put on the drive in 6 years? im impressed especially with never having to change the upper gears.
Old 10-19-2012 | 09:26 PM
There is a nice single arneson asd 7 in the classifieds I bet you could get a good deal on. You could run bravo or surface style props. Have more strength then ANY drive that still uses XR gears.
Or go with the SCX or SCX-4 since they use larger gears
MMW are just to expensive IMO for still being a bravo based drives with junk gears in them
Good luck either way you go and we look forward to hearing how it all turns out
offshorexcursion is offline
