Fogging out 502/454 MPI's.
How do you go about this, in the past i will put some 2stroke in the fuel filter while i run it but it just doesn't seem to get the ***ging smoke that i want, didn't know how other do this. Because of the air plentum i wasn't sure if you can fog through the throttle body.
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
portable gas tank fill with gas / a quality 2 stroke outboard oil, this all depends how much gas using and a good quality fuel stabilizer - pour this in the portable gas tank -shake it all up.
Next pull your fuel line at the motor side inlet - hook your portable gas tank mix then run your motor on the water hose.
This is Mercruiser and Volvo Specs
Do not forget to pour fuel stabilizer in the boats fuel tank also
i do it with a 6 gallon tank and 2 stroke oil,,i also fog through the plenum and yes if you use crc foaming fogging oil it works great to keep the valves,valve seats and cylinder walls oiled up to keep them from rusting..you can get the crc brand from advanced auto parts for like 5 bux a can..every little bit helps...i fog the engines when i have them hooked up to my antifreeze tank when the engine is hot and im pumping antifreeze through the engines....
Mixing the cocktail as described above, could I just run a gas line to a has can as long as it is far enough from the engine bay and run two gallons through? Will that be enough to coat the internals well enough and safe enough not to blow myself up?
Any EFI/MPI will adjust itself to keep running when fogging with 2 stroke oil/gas mix. You can't choke it out like you can on a carb motor. Heck, I can't even choke out my carb motors anymore with spray.
I've done it both ways, mixing up a can; and draining the fuel filter and adding 1/2 full with 2 stroke oil.
IF you want to go so far as to winterize with non-ethanol fuel in a separate tank, the mix in a tank method works pretty well. This is a good time to pump your tanks dry if you chose.
IF you have your ethanol fuel well treated, using the fuel filter and oil method works just fine.
