upgrade 502 to 525 fuel sys >
Old 10-27-2012 | 04:17 PM
Default upgrade 502 to 525 fuel sys
Hi ,
I onw the Sea ray P 22 with 502 Merc on it , it's 2010 model.
It would be nice to have a bit more power than stuck 380 hp.
I found 525 intake and ECM sys as it shows .Can I put this in to my 502 with cam.?[IMG][/IMG]
mikehonda is offline
Old 10-27-2012 | 04:19 PM
Old 10-27-2012 | 04:31 PM
And this is my baby
Old 10-27-2012 | 04:38 PM
Dave M's Avatar
Veteran: Navy
Originally Posted by mikehonda
And this is my baby
That's a pretty nice motor. Are you sure you want to start hacking it up? Plus, doesn't have the cat converter on it? Not sure if that would work with the 525 stuff.
You might be better off selling that motor complete and buying something else.
Dave M is offline
Old 10-27-2012 | 04:48 PM
The engine is catalyst so can't get to any mods.so far as I've been told...What else can do ?Don't see any other solutions...
8.2 mag is 430 hp...stilll under warr?? procharger will do a much better job...
FIXX is offline
Old 10-27-2012 | 04:54 PM
8.2 mag H. O. is 430 my is 380 hp here my friends Cobalt A25 with it:
Old 10-27-2012 | 04:57 PM
and the only diffrence is ECM ...as I know so far ,both have dts so what if I swap the ECM's ?
Old 10-27-2012 | 06:00 PM
Boats are not honda's. You shouldn't approach this hobby thinking you can swap around engine parts and see any appreciable speed gains.
Crossett is offline
Old 10-27-2012 | 06:13 PM
Changing the fuel system isn't going to do anything other than cause problems. None of this is just bolt on and go.
Griff is offline
