Sea water pump
I have an HP 500 EFI with a Bravo 1 drive. Recently the boat alarm went off due to overheating (I was at idle speed) I immediately turned the boat off. I checked the impeller and found the impeller in pieces. I was able to retrieve all the impeller pieces from the engine. I replaced the impeller and the housing. I took the boat for a ride and the boat ran fine, the temp was at normal temp range of 150 at 70 MPH. The following week I took the boat out and the impeller and the impeller housing blew into pieces. The boat was at idle speed when this happened. The same thing happened three years ago. The hoses are in good shape. Any clues on what to look for?
Possibly a blockage in the hose between the drive and pump, or loose hose clamps allowing air in and the pump to run dry. Was there sea weed wrapped around the drive cutting off the water supply? The pump must be running dry and destroying the impeller.
There was no seaweed and the hose is in good shape. I never thought about a loose clamp. I am wondering if the hose in the drive is collapsing cutting off the water supply. I'm also wondering if the pulley on the pump could be bad.
What did the inside of the new housing look like before you put it on? The housings I've purchased had so much flashing that they would chew up an impeller in no time. I have always cleaned and ported every housing. I got tired of having to buy new housings every year so I went stainless last year.
. I still have two nice polished stainless inlet outlet fittings sitting here doing nothing . Needless to say i'm not very happy....
Wondering if anybody else had this problem or is it just my luck .Sorry for the hijack , don't want to start a thread on this just yet .
The stainless steel "lifetime" sea pump overhaul kit from Cp Performance looks like a real nice piece. I was looking at it last winter when I replaced my empeller but at $190.00 it was out of my price range because I was also finishing up a new motor. I will more than likely go that route in the future though. I really like the stainless steel sea pump body and it looks like a real clean piece.
@ The Deep.....I just saw your post. Good to know! Could you p/m me the name of the company you bought yours from please. I might avoid that particular company. Thanks, Mark
